User Login - Perspectives or PAx or PAW or Contributor
Paul-TM1
Post by Paul-TM1 »
I am trying to get how our users are consuming TM1 data. I want to know how many used which client tool (Perspectives or PAx or PAW or Contributor) and when they last logged into them. I have transaction log that gives us info of last login, but does not give us which client they used. Is there a way to get that info?
We are using PA-2.0.9.
PAx and PAW both are version 54.
Can someone help me how to get the info?
Paul.
macsir
Version: PAL 2.0.9
Re: User Login - Perspectives or PAx or PAW or Contributor
Post by macsir »
Not really, all you have is tm1login.log file which captures all logins from all client software.
The only thing I did is dig up the log file from PAW to know the client is on that platform.
ykud
Post by ykud »
Tm1top and it’s logging reincarnation captures application context that tells you whether it’s tm1web or tm1application (contributor). For Pax vs Perspectives you can look at thread id: old api generated long numeric thread ids and rest api starts from quite low numbers and also has the : in it
Here’s how to configure top logging:
https://www.ibm.com/support/knowledgece ... ments.html
Paul-TM1
Post by Paul-TM1 »
Thanks Macsir and Ykud for responding.
Macsir, your idea of "log4j.logger.TM1.Login=DEBUG, LOCK" is good for future. I will get that added and it will be helpful in the future.
Ykud, I will try this method for future. I do not keep these log files for a long time.
Paul.
