PA Cubes recalculating different values
cdhodge2002
I am seeing a weird issue where the aggregated numbers in my cube are changing values based on dimension orientation or just when I recalculate my cube. This seems to occur only on "Version" elements that are created. The cube that I am seeing this in does not have a rules file. I have restarted the TM1 service but the issue persists. Has anybody seen an issue like this before and figured out the cause? I opened a case with IBM and am still waiting for a resolution.
- paulsimon
- Version: PA 2.0.5
Re: PA Cubes recalculating different values
I have not seen this in a cube that has no rules.
One possible cause might be that the formatting that gets applied can vary depending on the position of the dimensions. Do you possibly have formatting in the Version dimension on a Variance Ratio as well as on the Measures dimension? Could this possibly explain it?
If that is not it, then I suggest you take some screenshots and send them to IBM.
