Point Workspace Views to different TM1 Server
tm123
OLAP Product: tm1, cognos bi
Post by tm123 »
I need some help in regards to object migration from one server to another, in PAW:
I have both databases ( Dev and Test) on the same server, one called FnP_Dev and the other one FnP_QA
I created all the books and views in DEV and now when I try this Lifecycle Management to migrate them to QA, yes the package gets created and it gets migrated, but all the Views are still pointing to DEV Cubes
I have only one Workspace Server and there I have 2 databases setup.
And I cannot see how I can even change the Database name in the Views
WHen I go to setup SOurce to Target Mapping, on the Drop Down for Source I have Only "DEFAULT" and on the Drop Down for Target I also have only "DEFAULT"
Workspace_Source_target Mapping.PNG (21.52 KiB) Viewed 3469 times
Is there any way to change the Database Name after the Vews are migrated?
Thank you!
Re: Point Workspace Views to different TM1 Server
After you have selected Default in BOTH the Source and target it will provide you with additional dropdown boxes underneath each where you can select your source and target TM1 services. These dropdown boxes are only visible AFTER you select the Environments.
