PA for Excel isConnected VBA Function
Adam
OLAP Product: IBM PA
Version: 2.0.9.x
Post by Adam »
Assuming you're using IBM Planning Analytics for Excel (PAX/PAFE) alongside the API as documented by IBM, I wanted to share a VBA function that will return True when users are successfully logged into the target server.
Function isConnected(givenConf As Boolean) As Boolean
	' In the below row, substitute XXXXXXX with your ServerName
	Dim apiHeader As String: apiHeader = "/tm1/XXXXXXX/api/v1/ActiveSession/User/IsActive"
	Dim apiResponse As Object
	If Reporting.ActiveConnection Is Nothing Then
		Exit Function
	Else
		Set apiResponse = Reporting.ActiveConnection.Get(apiHeader)
	End If
	If apiResponse Is Nothing Then
		Exit Function
	End If
	If apiResponse.Properties.Item("value").Value = "true" Then
		isConnected = True
	Else
		Exit Function
	End If
End Function
More effective than my prior approach of calling for TM1User given caching. I figured putting this up here will save other people time.
Take care.
Take care,
Adam
Re: PA for Excel isConnected VBA Function
Thanks Adam
