I was setting up a Cognos & TM1 environment. TM1 Admin, Data and Web server all hosted in a single server. Cognos is installed on a different server.
To integrate the Cognos security with TM1, I followed the steps as recommended by IBM:
i.e. files variables_TM1.xml, planning.html, pmhub.html, and tm1web.html were placed in the Cognos server under webcontent directory & server entries modified with TM1 server details.
Deployed the instances from an already running server, Modified the required parameters inside the configuration file with ServerCAMURI and clientCAMURI entries.
Now In TM1 Client Architect or Perspectives, in Server Explorer, the list of available TM1 Servers is displayed, but it is not possible to connect to any of them with integratedSecurityMode=5 .There is no error, just a white background and nothing happens & then it hangs.
If I change the integratedSecurityMode=1 , it works fine.
This makes me believe something wrong with authentication with Cognos. But yet to get a clue.
Thanks in advance for suggestions.
Mayank
TM1 Authentication with Cognos BI
mayankthu3@gmail.com
- Version: 10.2
- Excel Version: Excel 2016
- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
Re: TM1 Authentication with Cognos BI
I assume that TM1 and Cognos are on different servers.
Anyway, you should add your Cognos server to 'local intranet' list in IE. With ISM=5, Architect opens a mini-IE window to authenticate (your white window), and it's blocked as pop-up window by IE
- Version: 10.2
Hi Elessar,
I tried the steps as suggested but still issue persists
BR
Mayank
BR
Mayank
- Elessar
- Version: 2.0.9
Please paste a screenshot of this "white background"
Can you authenticate well in TM1web?
burnstripe
- Version: 2.0.9
Stick the planning.html and pmhub.html here
<BI Install>/webcontent/bi
Create folder path
<BI Install>/webcontent/bi/tm1/web
Stick the tm1web.html here
Go to this location
<BI Install>/templates/ps/portal/
Put the variables_tm1.xml and variables_plan.xml files here.
Restart iis on bi server.
If you still can't access after this double check your parameters in tm1s.cfg for servercamuri and clientcamuri are correct, they should match the settings in your BI config
Still can't access, then a firewall may be blocking access. Test this by trying to access the BI gateway within a browser opened on your tm1/pa server. If the page doesn't render but works fine on the BI server, most likely the port BI is using is blocked
Create folder path
Go to this location
- Version: 10.2
Hello All,
I found the solution. I wasn't able to login to CA when SSO is configured with CA gateway on IIS , This is a product bug in the version 11.16 which I was configuring.
Interim Fix pack link:
https://www.ibm.com/support/pages/cogno ... erim-fix-1
