ElementParent rule in Hierarchies
Posted: Tue Jul 14, 2020 8:22 am
by mvaspal
I am trying to write a "% of Parent" -type of rule in an alternative/virtual (not sure what's the official term...) Hierarchy. Here below is a simplified code of this
The rule for the primary/base dimension looks like this, and works fine:
[Measures: '% of Parent'] = [Measures: 'Gross Sales'] \ DB('Sales',!Version,!Time,ELPAR('Products',!Products,1),'Gross Sales');
Then I have a Hierarchy, called "By Bucket1", here is my try:
[Measures: '% of Parent in Bucket1'] = [Measures: 'Gross Sales'] \ DB('Sales',!version,!Time,ElementParent('Products','By Bucket1',!Products,1),'Gross Sales');
The rule returns only 0s. Then I created a test S measure, called TestParent:
[Measures: 'TestParent'] = S:ElementParent('Products','By Bucket1',!Products,1);
This measure correctly displays the element parents in the By Bucket1 hierarchy, and so I am a bit puzzled on what I'm doing wrong in my % of parent rule?
Any help appreciated,
Thank you
Matyas
Re: ElementParent rule in Hierarchies
Posted: Tue Jul 14, 2020 12:11 pm
by PavoGa
In the DB statement, the argument for the hierarchy element has to be fully qualified:
'dimname:By Bucket1:' | ElementParent('Products','By Bucket1',!Products,1)
Posted: Tue Jul 14, 2020 12:29 pm
by MarenC
I was reading that you don't need the dimension qualifier in a DB.
I also read that you shouldn't use the pipe.
'By Bucket1': ElementParent('Products','By Bucket1',!Products,1)
Is this incorrect?
Maren
Posted: Tue Jul 14, 2020 12:30 pm
by mvaspal
Excellent, that's it, thank you for your help!!
Posted: Tue Jul 14, 2020 12:33 pm
by mvaspal
@Maren - your syntax worked too
I guess because in a DB() function, the dimension order is fixed, so no need to qualify it
Posted: Wed Jul 15, 2020 1:34 pm
by PavoGa
MarenC wrote: ↑Tue Jul 14, 2020 12:29 pm I was reading that you don't need the dimension qualifier in a DB.
Is this incorrect?
Maren
I've not read that on the pipe, but we do use it without any problems. However, I am UP with not using it. I try to avoid it anyway possible. Did not know this particular syntax would work, so thank you for that!
