Planning & Analytics Local Server Startup
pisrikrishna
- OLAP Product: IBM Planning & Analytics
- Version: 2.0.9
- Excel Version: 2019
Is it possible to start TM1 Server without connecting to TM1 Admin server for development purposes? I want to run Architect and Performance modeler and so fat I am unable to bring them up. Any help is appreciated.
- scrumthing
- Version: 11.x
- Excel Version: MS365
Re: Planning & Analytics Local Server Startup
AFAIK the answer is no.
As both of those tools use the old C-API they need the admin server to connect. How would you tell architect to connect to your database without specifying an admin host.
Rest based clients should (technically) be able to connect to the instance without the admin server. But most tools rely on the admin server to get a list of the available instances.
PS: Do not use performance modeler. <-- just my personal opinion.
- paulsimon
- Version: PA 2.0.5
You can start a Local Server for development purposes, if that is all you want?
You probably won't be able to use Performance Modeler against it, but you can use Perspectives and Architect.
I tend to agree with the previous poster - don't use Performance Modeler. AFAIK IBM are going to drop it anyway.
Paul SImon
Paul SImon
pisrikrishna
- Version: 2.0.9
Thanks for the clarification.
