Turbo Integrator - Data tab dont run?
Posted: Fri Jul 03, 2020 1:30 pm
Hello Community,
i have a issue with a TI that i created yet, first i create a View and some subsets and assign them to the view, works pretty well.
The View looks like what i need, now i used this view as Datasource and want to create a ASCIIOutput log if the Value is not 0 or 1. But the Datatab never runs, i removed the IF to log every Value, but it dont log anything... Also my code on the prolog dont execude.
Anyidea why just the prolog runs fine?
No errors in the Log.
Version 2.0.9
Thanks!
Datatab looks like:
Edit:
In the Prolog i also changed the temp view to a permanent view and selected them as Datasouce.. so its a normal Process with a View, but i dont get the logs i want to see
Sidequestion:
Is this still right to define a temp view a datasource?
Version 2.0.9
Thanks!
Datatab looks like:
#IF(Value <> 0 & Value <> 1);
ASCIIOutput( 'D:\Planning_Analytics\Custom_Logs\Logger\SchluesselCheck_' | sRunID | '.txt', V1, V2, V3, V4, V5, V6, V7, NumberToString( Value ));
#ENDIF;
Sidequestion:
#DataSourceType = 'VIEW';
#DatasourceNameForServer = Cubename;
#DatasourceCubeview = 'Viewname';
