Bringing Allocated Resource from another cube
dparkar
Version: 2.0.7
Excel Version: 2017
Post by dparkar »
Hi All
I have a scenario in which i need to bring the name of the resource who is allocated
for example i have 2 cubes
in the 1st cube there is an option for input, if we type 1 in front of Anne in allocated resource, then when we run the Ti Anne's name should appear in 2nd cube in the same combination.
Thanxx in Advance.
Re: Bringing Allocated Resource from another cube
Well, urrrm, what have you actually done?
The requirement you state is pretty simple. You just need a zero supressed view on the first cube with only the "Allocated Resource" measure selected. Then on the data tab take the variable from the Resource dimension and write it with CellPutS to the "Resource" measure in the 2nd cube.
dparkar
Version: 2.0.7
Excel Version: 2017
Post by dparkar »
Thank you....!
