subset to dimension using t1 process
kalyan846
Excel Version: office 365
Post by kalyan846 »
Hi, please dont mind if it a silly Question,
In a dimension i have a dynamic subset, which i want to transfer same structure into another dimension
but that subset is having rollups.
i want the same structure into dimension,via ti process
Can any one help me please........
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Re: subset to dimension using t1 process
Post by ascheevel »
You can iterate through a subset using a WHILE loop and SubsetGetElementName. You can then add the returned name from SubsetGetElementName to the subset in your target dimension using SubsetElementInsert.
ascheevel wrote: Thu Apr 09, 2020 5:50 pm You can iterate through a subset using a WHILE loop and SubsetGetElementName. You can then add the returned name from SubsetGetElementName to the subset in your target dimension using SubsetElementInsert.
OP is wanting to create a new dimension out of the subset of an existing dimension, hierarchy and all. Take a look at Bedrock. I believe it has a process that does this.
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Post by ascheevel »
Thanks Tomok, looks like I misread. There is indeed a bedrock process that will clone a dim from a subset. If OP is on 10.2 as their profile suggests, I think it'd be this process: Bedrock.Dim.CloneFromSubset
