writing a rule for 70+ elements that all start with XX...
kbogies
Version: 9.1sp4 64x
Post by kbogies »
I'm trying to write some ratio rules in the Server Explorer and there's a pretty big IF; if elements [start with X....] then... Is there a rule that i can write for "starts with"? I'd really prefer not to write 72 individual rules for all the multi-level decendants (which all start with X).
Thanks!
Martin Ryan
Re: writing a rule for 70+ elements that all start with XX...
Post by Martin Ryan »
Try "subst"
E.g. if(subst(!Elem, 1, 2)@='xx', true, false).
2c
Functions like SUBST and SCAN can be very expensive in terms of calculation efficiency. I would approach this by setting an attribute for the elements based on the starting string and basing the rule off a simple attribute lookup rather than a string function.
kbogies
Version: 9.1sp4 64x
Post by kbogies »
just to follow up... i used an attribute on all 70+ elements to use for a lookup in a reference cube. seems to work pretty smoothly.
Thanks!
wissew
Version: 9.5.2; 10.2.2; 11
Excel Version: 2003 SP3 - 2013
Post by wissew »
kbogies wrote:just to follow up... i used an attribute on all 70+ elements to use for a lookup in a reference cube. seems to work pretty smoothly.
Thanks!
Correct, attributes are the way to go!
