Hello, i was wondering how you can get the attributes Name, Memory Used and #Elements from a dimension. Best case would be, if i could use the REST Api. Same thing would have to be possible for cubes, i want to get the attributes: Name and Memory Used.
Thanks for any help
Manuel
Get cube and dimension values from TM1
manuel10002
- Version: 10.2
- Excel Version: unkown
Re: Get cube and dimension values from TM1
Where and how do you want to consume this output ?
manuel10002
- Version: 10.2
I would want to use the data in a java application and get the data via REST API. As of how the data is gonna be used i can't exactly say because im not in charge for this part.
Then I cannot really help. Hopefully there are properties of a dimension that you can use. Or you retrieve information from the }Stats cubes.
