Upload data from excel file into tm1 cube via TI process
Posted: Thu Apr 02, 2020 4:36 pm
I have to create a cube and its dimensions and load an Excel file in this cube.
The file contains many columns and I have to compile the dimensions from this file.
My question is as follows: i have 3 columns which will be gathered under the same dimension (a fine level and 2 consolidated levels).
How can i do to uplode the data of this file in the cube? should i leave that fine levels and remove the consolidated columns?
Looking forward for your valuable suggestions.Thanks in advance.
