IBM TM1 10.2 Applications Security.
joseluis.senas1
Version: 2.0.46
Excel Version: Office 365 32 bit
Post by joseluis.senas1 »
Hello all,
Any advice will be very much appreciated.
We have IBM Cognos TM1 (10.2) and IBM Cognos BI (10.2) installed in two different servers.
We need to shut down our IBM Cognos BI server due to obsolescence.
We are still using IBM Cognos TM1 for some models and applications (pmpsvc).
Migrating to IBM Planning Analytics is not an option at this time.
We need to switch back security from integrated security 5 into integrated security 1, because we will no longer be able to use IBM Cognos BI as authentication provider.
So, question is: how do we switch back security in TM1 Applications (pmpsvc) from Cognos BI into TM1 native security?
Once again, thanks in advance for any advice.
Re: IBM TM1 10.2 Applications Security.
joseluis.senas1 wrote: Tue Mar 31, 2020 4:09 pm We need to switch back security from integrated security 5 into integrated security 1, because we will no longer be able to use IBM Cognos BI as authentication provider.
TM1 10.2 comes with a license for a limited BI install that includes CAM security. You should be able to download this from IBM and install it on your TM1 server to take the place of your BI instance for security in TM1.
