Basic question on meta data and data
manu0521
OLAP Product: IBM TM1, Planning Analytics
Version: PA 2.0.5
Post by manu0521 »
I have a pax excel which has some fields for entry by user and there is an action button which calls a TI ,
In the TI I recive the paramaters with data source as none and then do some validations , now if the validartions are successful I need to add the parameter value to a dimension ,
Since my meta data and data is disabled as my source is empty , how would i enable them here , all i am doing is sending data from my pax sheet via action button .
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Re: Basic question on meta data and data
Post by ascheevel »
Just do you DimensionElementInsert in the PROLOG or EPILOG tabs after your validation.
ascheevel wrote: ↑Mon Mar 30, 2020 2:35 pm Just do you DimensionElementInsert in the PROLOG or EPILOG tabs after your validation.
Not in Epilog tab, use the Prolog tab.
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Post by ascheevel »
Thanks for setting me straight Wim!
Yep, use DimensionElementInsertDirect if trying to add the element in the EPILOG tab.
