Zero Suppression and Undef
HighKeys
OLAP Product: TM1 / TM1 Web / Perspectives
Version: Planning Analytics V2.0.9
Post by HighKeys »
Hello Community,
i'm woundering how to solve the issue that 0 values calculated in Rules are still get showed in a Zero suppressed View, i found in the docs i could assing the "Undef" Value (which means no data input and not a real 0 (it would be data input), if i understand it right).
But now the Value get shown as #N/A, if i use 0 then "undef" it get shown in the zero suppressed view.
How can i solve this?
The Rule Code:
['Abwesenheiten rMA', 'HR'] = IF(ELISPAR('Kennzahlen Personaleinsatz-Reporting', 'Brutto Einsatz rMA', 'Abwesenheiten rMA') = 1, UNDEF, Continue);
#Or
['Abwesenheiten rMA', 'HR'] = IF(ELISPAR('Kennzahlen Personaleinsatz-Reporting', 'Brutto Einsatz rMA', 'Abwesenheiten rMA') = 1, 0, Continue);
HighKeys
Re: Zero Suppression and Undef
Post by HighKeys »
In the same Cube, i tried to get an AVG in a C Element but it also count the 0 values.
C:ConsolidatedAVG(2, 'Personaleinsatz-Reporting', !Tag, 'HR', !MA-Pool, !Kennzahlen Personaleinsatz-Reporting);
Flag is Set to 2
If you are using those consolidated functions then make sure you read this tech note https://www.ibm.com/support/pages/node/3117345
As to the issue in the initial post if you set the rule to N level only you should find the suppression works.
