Cell Type is Real weirdness
MarenC
Excel Version: Excel 2016
Post by MarenC »
I have a process with the following logic on the Prolog:
vAdminCube = 'Admin Cube';
vDay = cellgets(vAdminCube, 'Actuals', 'Current Year', 'Day');
sFile='C:Path\testday.txt';
If( vDay @= '03' );
    Asciioutput(sFile, 'Test Output');
Endif;
The above errors with the message Cell Type is Real. This doesn't surprise me because vDay element is actually Simple.
Also the Asciioutput doesn't execute.
Here comes the weirdness:
If in the above code I insert the following code before vDay the cell Type is real error still happens but the Aciioutput now executes!
nSerialNow = NOW;
vTimeStamp= TimSt (nSerialNow, '\Y\m\d\h\i\s');
vDay=subst(vTimeStamp,7,2);
If( vDay @= '03' );
Endif;
So it now ignores the second vDay variable declaration. I presume this is related to the fact that you can't change the data type of a varibale in TM1 but this seems like weird behaviour.
Does anyone have an explanation as to what is going on?
Re: Cell Type is Real weirdness
It makes perfect sense to me. In your first example trying to pull a numerical value with a CellGetS results in an error so no value is assigned to vDay and therefore the If( vDay @= '03' ); is false and nothing is written to sFile. In your second example, you are assigning a value to vDay and then trying to modify it with an invalid CellGetS statement. This doesn't work so your original assignment to vDay remains intact and the If( vDay @= '03' ); evaluates to true and the file is written.
MarenC
Post by MarenC »
Hi Tomok,
yes it makes perfect sense to me now! :D
Maren
