i read much about the Hierachys which are added with PA 2.0.5, at the moment we dont use the new Hierarchy system, but i think its worth a try.
I cant find any info according to the DBR(W) formula if there was added a support of hierarchys.
So my question is, we are using some sheets where i used DBRW formulars to read the values, this should be not affected if i'm right?
We also have a websheet where ppl can add comments to our Comments cube, its also solved with a DBRW formula, if i just write directly in the main hierarchy (like no specific one is selected) can i see the data in each hierarchy or just in the main?
If i understand it right i should see it in every hierarchy cause the N Level Element will be the same and not created separately for each hierarchy correct?
Thanks for helping me to understand this topic correctly
All the best!
