Hyperlink in TM1 Web
TimeTq
Version: 2.0.9.58
Excel Version: 2019
Post by TimeTq »
Hi, I want to create a hyperlink from xlsm file to another xlsm file ( both of them on server).
I tried with a TM1://ServerName/blob/PUBLIC/.\}externals\filename.xlsm. Name of the file i got from filename.blob file (ENTRYREFERENCE) in an }application folder. After I click on hyperlink i got "Failed to open destination workbook. Make sure the file has not been renamed or deleted."
Does someone know how to fix it?
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Re: Hyperlink in TM1 Web
Post by Mark RMBC »
HI,
You need to use the name of the file in the externals folder, not the applications.
Also, I have found that if I try to hyperlink from excel and then publish the form to the application folder it fails. So I just create the hyperlink, don't test it in excel and then publish it. Then test it on the web.
regards,
mark
TimeTq
Version: 2.0.9.58
Excel Version: 2019
Post by TimeTq »
Hi, there is .blob file in application folder. If you open it with notepad, you'll find a name of file same as in externals folder (ENTRYREFERENCE).
I made a working hyperlink but on .xlsx file from .xlsx file. Is there problem with xlsm files?
orlando
Version: PAL 2.0.8
Post by orlando »
TimeTq wrote: Tue Feb 25, 2020 10:07 am Hi, I want to create a hyperlink from xlsm file to another xlsm file ( both of them on server).
out of pure curiosity - why are you not using an "action button"?
best regards
orlando
orlando wrote: Wed Feb 26, 2020 10:57 am
best regards
orlando
True, if wanted, the button formatted as a hyperlink.
Mark RMBC
Version: 10.1.1
Post by Mark RMBC »
Yes I was wondering about the Action Button too.
But for information, I can hyperlink to a .xlsm too
