TM1 cleaning up
Posted: Mon Feb 17, 2020 10:28 am
by WayneBo
Dear all TM1 experts:
I have lots of elements in various dimensions which I am sure not been used at all, which I would like to delete.
I also want to know which elements from what dimension been used in what cubes, so that I can do some clean ups (ie, delete those not been used at all elements and dimensions)
Is there any object cube or something else that I can run ( like a report or not) to provide me a summary how is my elements and dimensions been used in which cube or not?
Or please kindly advise how do I find it out rather than I manually check one by one.
Thank you
W
Re: TM1 cleaning up
Posted: Mon Feb 17, 2020 12:07 pm
by tomok
WayneBo wrote: ↑Mon Feb 17, 2020 10:28 am Dear all TM1 experts:
Thank you
W
There's not going to be any magic bullet that will give you this information. To me, there are three scenarios that must be explored before you can determine whether an element is still being used:
  • Is there any data stored against it in a cube,
  • Is it used in a rule and,
  • Is it used in a TI process
For the first one you are going to have to go cube by cube, for each cube that uses the dimension, and create a view that shows the leaf level elements of the dimension in question on the rows and then a top of the house consolidation for the other dimensions in the titles. This will show you which elements have no data.
For the second and third you can take a text editor like Notepad++ and open all the .RUX and .PRO files and do a search for the elements that have zeros in the first search above. These are the exact procedures I follow when I am looking for elements to drop. It's not perfect but it's never failed me yet.
Re: TM1 cleaning up
Posted: Tue Feb 18, 2020 5:18 am
by WayneBo
Thanks Tomok for your tips, I will do that.
W
Re: TM1 cleaning up
Posted: Tue Feb 18, 2020 5:30 am
by Wim Gielis
Elements can also be used in reports or Action buttons, even though there are no data posted against them. So I would propose to also go through the/some reports.
Re: TM1 cleaning up
Posted: Tue Feb 18, 2020 4:16 pm
by Emixam
I suggest you the Find in File function in Notepad ++
If you search for a specific Dimension or Element in your TM1 data folder, it will tell you exactly where these objects appear in your model. (.RUX, .PRO, .DIM, ...)
Cheers !
