Has anyone been able to do this using Cognos Integration Server or some other mechanism?
At the moment we extract to .csv from BW BI queries, split using VB Script then load in parallel using Runprocess in TI's (And flag files to manage completion status of the called processes). We do the parallel liad because of volume.
I really want to flip the approach and have PA in charge and send parallel queries to BW by executing SAP BI queries with passed parameters such as year and week. Not a complex requirement.
The documentation on Cognos Command Center and Cognos Integration Server is not that great. As I understand it, Cognos Integration Server cannot load to PA in parallel as it is just a standard client.
Without going into more detail on the options I have considered does anyone have experience/ ideas?
Reading from SAP BW and writing to PA in parallel
EvgenyT
- Version: PAL 2.0.8
Re: Reading from SAP BW and writing to PA in parallel
We used to connect to SAP BW with a help of SAP connector for tm1, but this was before PA. I believe SAP connector has been depreciated too, correct me if I am wrong
JohnO
- Version: 2.0.9.x
- Excel Version: Office 365 16
The old connector which could be used as a source for TI was deprecated. However they introduced new BW read/write functionality as part of Cognos Integration Server.
EvgenyT
Cool, thought so.
Did you look at running this as batch with CIS command line utility?
Then you could trigger it from a TI process/Chore with specified year/month etc parameters.
Let me know, will be interested in seeing how you go!
Evgeny
Evgeny
JohnO
- Version: 2.0.9.x
No I haven't got that far. I'm thinking that would need to work the following way:
1) Use RunProcess and run parallel TI's within TM1 which each would:
a) run the batch with parameters which would execute a SAP BI query and write the results to a text file - (as I understand it a direct write to TM1 is possible using CIS but no transform is possible)
b) On successful production of the text file then run a load TI which apply the required transforms
For this approach to be of benefit is would need SAP BI to be able to run the separate requests in parallel
Might be possible?
Might be possible?
EvgenyT
Yes, something along those lines.
Also, consider a staging cube to land SAP data? Then use it as a data source for further upstream transformations. Saves you from a hassle of dealing with csv files. Moreover, if you are dealing with numerous threads, consider using RushTi to manage processing queue.
Evgeny
Evgeny
