TM1 to PA Upgrade - Web Report Not Showing Last Line
rfielden
Version: 9.5.2
Post by rfielden »
We recently upgraded our TM1 instance to PA. Our P&L report when using Web is not displaying the last line of the report (which is income). The report works fine when using perspectives. Open issue with IBM for a week with no movement forward. Any assistance/insight would be appreciated.
Note: The report is an Active Form.
macsir
Version: PAL 2.0.9
Re: TM1 to PA Upgrade - Web Report Not Showing Last Line
Post by macsir »
Is it for every report? Maybe show some snapshots.
Insert a few extra rows under the active form area and add a border to the cells a few rows down then reupload the sheet and it will be fine.
rfielden
Version: 9.5.2
Post by rfielden »
Only active form reports having the issue.
Must of inserted the lines incorrectly as that did not work.
rfielden
Version: 9.5.2
Post by rfielden »
When I unhide the rows and columns, I am seeing a 0 AF format code in Column A for the CTO line in perspectives yet the web is showing an 'N' for the same line.
rfielden wrote: Thu Dec 05, 2019 6:27 pm Only active form reports having the issue.
Delete all rows apart from the first in the active form (the one that actually contains the tm1rptrow formula.
A few rows below that type a word into a cell, something visible. Update the file onto the server (with the af rows still deleted.)
You should now have the extra space so that the websheet stops at your typed word - assuming that works play about with changing the word to something less noticeable.
rfielden wrote: Thu Dec 05, 2019 6:35 pm When I unhide the rows and columns, I am seeing a 0 AF format code in Column A for the CTO line in perspectives yet the web is showing an 'N' for the same line.
This sounds like a bigger issue; I guess you have changed the default formula from column a to something custom - can you provide the formula that you are using? The web and perspectives can perform calculations in different orders - meaning that a dependent cell may not yet be calculated in the web in time.
rfielden
Version: 9.5.2
Post by rfielden »
IBM was able to recreate the issue in latest version. Defect PH20190 has been logged.
I will review latest post. The current AF report though does have 11 different sections (views).
