Hello Everyone,
I am trying to set SSO for Longview analytics.
Longview webserver - IIS.
To make it more clear on Longview Analytics, there a 2 clients
1. Long view Analytics Designer
2. Long view Web Client.
Till now I did the below steps:
Installed Cognos Analytics
Architect/Perspectives working with mode 5
Using ‘CAMNAMESPACE’, now I can able to login with windows credentials in both Designer and Web client in Longview.
As a try, give static 'campassport', it works in Longview Designer. But its not working in Web client.
After several attempts, I assume that 'CAM_PASSPORT' should be defined as Server-Variable in IIS. So that it can read by a function in Longview Analytics.
But absolutly no idea on how to set 'CAM_PASSPORT' of CA as Server-Variable in IIS.
Anyone has an idea on settig up Server-Variable in IIS? Is it right way of doing? Kindly share. Thanks
**** Kindly Ignore if its not related to this forum ****
Tm1 Datasource for Longview Analytics
kavitha2002
- OLAP Product: tm1
- Version: 10.3.10100.8
- Excel Version: 14
