Cost allocations by Department & Employee
Posted: Fri Nov 01, 2019 7:33 am
by CRP0021
Hello all,
I'm looking for an efficient way to setup rules to capture departmental salary allocations by employee and would appreciate any advice.
Basically there should be an input of allocation % by Department and by Employee. This would be the source view or the sender view. The receiver of the allocation would be the flip side and all rule based. I have a good understanding of the logic and how it should work just running into a roadblock translating this into rules. This could be split up into 2 cubes if necessary, I'm not bound by any design structure at the moment.
For simplicity here is a screenshot example of what I'm trying to achieve.
Thank you in advance!
Allocation example.png (28.15 KiB) Viewed 7754 times
