Createing a Report for only approved Data
QFmbongwa
OLAP Product: Microsoft SQL Server
Version: Planning Analytics
Excel Version: MS 2013
Post by QFmbongwa »
Hi I am new in tm1. I have "cube A" that has data and I have a TM1 application that is connected with "cube A", I would like to create Cube B that will get only approved data(approve in the application) from "Cube A". I would like to put data that has been approved in the tm1 application to Cube B and I would use Cube B as my data source for my reports. Please help :(
Re: Createing a Report for only approved Data
QFmbongwa wrote: Thu Oct 31, 2019 10:48 am Hi I am new in tm1. I have "cube A" that has data and I have a TM1 application that is connected with "cube A", I would like to create Cube B that will get only approved data(approve in the application) from "Cube A". I would like to put data that has been approved in the tm1 application to Cube B and I would use Cube B as my data source for my reports. Please help :(
New to TM1? Nothing like jumping right into the deep end. Accomplishing what you want will require an understanding of TM1 applications work, how your approval hierarchy is setup and a complete understanding of rules and feeders.
When you create an application in TM1 you have to designate an approval hierarchy. This will result in a cube being created called }tp_application_state}{xxxxxxxxxx}, where xxxxxxx is a random string created by TM1. In this cube you will find a measure called “State” in which will contain a numeric value. A value of 4 in this element means it has been approved. So now, the trick is going to be writing a rule that populates cube B with data from cube A whenever the node has been approved:
['Measure'] = N:IF(DB('tp_application_state}{xxxxxxxxxx}',!ApprovalDim) = 4,
DB('Cube A', !Dim1, !Dim2, !Dim3……!DimX),
0);
You'll also need to write feeders for Cube B. I'll leave that up to you. The code above is theoretical. I have no idea how many dimensions your cubes have nor their names. Also, the dimension containing the approval hierarchy will have to be in both Cube A and Cube B. Good luck.
