MDX - dynamic subset to filter by two other dimensions
Posted: Mon Oct 28, 2019 4:28 pm
by jamesbennett
This issue has come up before in other threads on this forum, but I'm having difficulty implementing it. I think it's a straightforward syntax error with my MDX but can't work out how to rectify it.
I have a row dimension, Course, which I want to filter by the values of two other title dimensions, Level and Mode. Course has element attributes which match the values of Level and Mode.
I put together this bit of MDX that works fine when selecting any combination of Level or Mode:
{FILTER(
{FILTER(
{TM1SubsetAll([Course])},
[Course].[Programme Type]=[GLOBAL Level].CurrentMember.Name
[Course].[Mode]=[GLOBAL Mode].CurrentMember.Name
However, Level and Mode also have consolidations that I might want to select to show All Levels or All Modes. In this case I do not want to filter by attribute of the Course dimension, as it would give me no values. I have tried adapting the MDX to account for this and have come up with the following:
{UNION(
IIF(
[GLOBAL Level].CurrentMember.Name<>"All Levels",
{FILTER(
{TM1SubsetAll([Course])}),
IIF(
[GLOBAL Mode].CurrentMember.Name<>"All Modes",
{FILTER(
However this gives me a syntax error "at or near character 7".
Is it my UNION or IIF that is wrong? I have checked the logic and can't see anything obviously amiss. What have I missed?
Re: MDX - dynamic subset to filter by two other dimensions
Posted: Tue Nov 05, 2019 9:48 am
by jamesbennett
Bump. Any insights?
Posted: Tue Nov 05, 2019 7:09 pm
by PlanningDev
Im not 100% certain, but I tested a few examples and I believe the issue is that IIF wants to return either a numeric value or a string value.
It appears that it is supposed to be able to return a set however in this case you are evaluating a string and so it seems to want a string value to be returned.
If you can return a string value from the IIF statement and then use something like StrToSet you can then perform your set expression outside the IIF which works.
I can't test your exact code but something like this should work
{UNION(
StrToSet(
IIF(
"{FILTER(
"{TM1SubsetAll([Course])}")
StrToSet(
IIF(
"{FILTER(
{TM1SubsetAll([Course])}",
Posted: Thu Nov 07, 2019 10:34 am
by jamesbennett
Thanks for your reply PlanningDev. Using your code with the StrToSet seems to work well - however the UNION still doesn't seem to work. It doesn't matter in which order I put Level or Mode - the Course dimension only filters by the first one and ignores the second one. Testing each block of code individually does what it should - but putting them together inside a UNION does not. Any ideas as to why?
Posted: Thu Nov 07, 2019 1:33 pm
by Mark RMBC
I haven't quite worked out what Global Level or Mode is, a subset, a single element in a dimension of one element?
I don't think the UNION is the issue personally. Have you tried doing something like just to check it returns something:
{UNION(
StrToSet(
IIF(
"{FILTER(
{[Course].[Any old element]}
You could try the following:
{UNION(
StrToSet(
IIF(
Instr(1, "All Levels", [GLOBAL Level].CurrentMember.Name) = 0,
"{FILTER(
StrToSet(
IIF(
Instr(1,"All Modes", [GLOBAL Mode].CurrentMember.Name) = 0,
"{FILTER(
cheers, Mark
Posted: Thu Nov 07, 2019 2:04 pm
by jamesbennett
Hi Mark,
Apologies - Global Level and Global Mode are both title dimensions in this cube, the values of which correspond to attributes in the Course dimension. E.g. Global Mode has two elements (FT and PT) grouped under a consolidation All Modes. Each element in the Course dimension has a Mode attribute equalling FT or PT, but obviously not All Modes - hence why I want to exclude these consolidations from the filter.
Your suspicion that it's not the Union at fault might well be correct - I've just tried unioning the Level filter with a specific element (that would not be included in the first set) and it returns it correctly.
Your suggestion with the Instr function unfortunately returns the same as PlanningDev's original syntax with StrToSet. It works for either Level or Mode (whichever is placed first in the Union) but not both together.
Edit: I realise I've got this wrong. Mark's syntax above is working fine, just not giving me what I want. If I select Mode=PT and Level=LevelA, it returns all courses with mode=PT (regardless of level) plus all courses with level=LevelA (regardless of mode). Whereas I want it to return just those courses with Mode=PT and Level=LevelA.
Posted: Thu Nov 07, 2019 2:54 pm
by Mark RMBC
I am slightly confused, which may well be me!
What does the cube have anything to do with this, that is what I am struggling with.
When you say Global Level and Global Mode are both title dimensions in this cube, which cube?
And in reality Global Level and Global Mode are both just dimensions are they not?
I also don't understand what you mean by If I select Mode=PT and Level=LevelA? Where is that in your MDX? There is no reference to a parameter for PT or A in your MDX?
Having said that what happens if you replace Union with Intersect?
cheers, Mark
Posted: Wed Nov 13, 2019 4:39 pm
by PlanningDev
jamesbennett wrote: ↑Thu Nov 07, 2019 2:04 pm
So the MDX is not giving a syntax error, rather its not returning what you expected? If thats true then looking at your MDX, I believe you would not need a UNION. You would want to put both conditions into the same FILTER statement using AND. Then you would get elements that have BOTH Mode=PT AND level=LevelA.
Posted: Wed Nov 13, 2019 5:17 pm
by Mark RMBC
Hi PlanningDev,
Maybe you can explain where in the MDX Mode=PT AND level=LevelA is referenced because it is confusing me!
Posted: Wed Nov 13, 2019 7:36 pm
by PlanningDev
Mark RMBC wrote: ↑Wed Nov 13, 2019 5:17 pm
Hi PlanningDev,
Im guessing but I believe its the two filters. Programme Type = Global Level and then Mode = Global Mode. Mode = PT is just his example of the Mode attribute of dimension Course equals the current member name of the selected element from GLOBAL Mode dimension (which is a title dimension). So essentially if you selected PT from the title dimension Gobal Mode then it should filter the Course dimension for only elements that have a Mode attribute that equals PT.
{UNION(
StrToSet(
IIF(
"{FILTER(
[Course].[Programme Type]=[GLOBAL Level].CurrentMember.NameCode: Select all
StrToSet(
IIF(
"{FILTER(
[Course].[Mode]=[GLOBAL Mode].CurrentMember.NameCode: Select all
Posted: Thu Nov 14, 2019 6:06 pm
by Mark RMBC
Ha! Thanks PlanningDev, I get it.
I think you are correct about the and statements, but I tried the following and it seemed to work:
StrToSet(
IIF(Instr(1, [GLOBAL Level].CurrentMember.Name, 'All Levels', 1) >0 or Instr(1, [GLOBAL Mode].CurrentMember.Name, 'All Modes',1) >0,
"{TM1SubsetAll([Course])}",
"FILTER({TM1SubsetAll([Course])}, [Course].[Programme Type]=[GLOBAL Level].CurrentMember.Name and [Course].[Mode]=[GLOBAL Mode].CurrentMember.Name)"))
Rather embarrassingly in my instr in the previous comment I got the parameters the wrong way around! All Levels should come after the currentmember (this is obviously corrected in the code above, I also added the last parameter, 1)
Regards, Mark
Posted: Tue Dec 03, 2019 4:30 pm
by jamesbennett
PlanningDev and Mark,
Sorry for the delay in replying, but wanted to say thanks - I've made a couple of tweaks to your syntax but got it working exactly as intended now - couldn't have got there without you both!
Posted: Tue Dec 03, 2019 5:24 pm
by Mark RMBC
Hi James,
no worries, tbh without planningdev I wouldn't have got there either!
Just for my sanity, what were the tweaks you made?
regards,
mark
