Hi All:
I am creating a dynamic subset on my time dimension by MDX.
SubsetCreatebyMDX('MDXSet','{intersect(
Filter( TM1SubsetAll( [ContinuousTime] ), [ContinuousTime].[PreviousNumber] >= '|vEndNo|' ),
Filter( TM1SubsetAll( [ContinuousTime] ), [ContinuousTime].[PreviousNumber] <= '|vStartNo|' ) ) } ' ,0 )
I also have 2 variables vStartNo and vEndNo, which will get the relevant attributes from Time Dimension, those attributes are in number format.
vStartNo = ATTRN('Continuous Time', vTodayAU, 'StartNumber');
vEndNo= vStartNo - 21;
But when I pass the variable into the MDX the process says syntax error on or before:" vEndNo|' )Filter ( Invalid operator ".
I guess the problem is at where the variables been signed into MDX, ( >= '|vEndNo|' )
Could any expert provide hint.
Very much appreciated.
W
Variable/Parameters in MDX
- gtonkin
Re: Variable/Parameters in MDX
Looks like vStartNo and vEndNo are numeric values and you are trying to join them to a string.
You will need to convert them to string first e.g. NumberToString(vStartNo).
p.s. have not looked too deeply at the rest of the MDX for validity.
- PavoGa
- Excel Version: 2013 PAW
If you were to use EXPAND instead of string concatenations, the numeric values are handled. For example:
An alternative MDX statement would be this, which may be a bit faster in execution:
sMDX = EXPAND('intersect(
Filter( TM1SubsetAll( [ContinuousTime] ), [ContinuousTime].[PreviousNumber] >= %vEndNo% ),
Filter( TM1SubsetAll( [ContinuousTime] ), [ContinuousTime].[PreviousNumber] <= %vStartNo% ) )');
SubsetCreate('MDXset', sMDX, 0);
sMDX = EXPAND('Filter( TM1SubsetAll( [ContinuousTime] ),
[ContinuousTime].[PreviousNumber] >= %vEndNo% AND
[ContinuousTime].[PreviousNumber] <= %vStartNo% )');
Ty
Cleveland, TN
Cleveland, TN
WayneBo
- OLAP Product: TM1 Planning Analytics
- Version: 2.0
- Excel Version: 2019
Hi:
Thank you guys for the help.
Great tips and helps.
Best Regards
W
Best Regards
W
