Choose to "Refresh Client Interface on Running Process"
John Hammond
Version: TM1 Server 11.8.003
Excel Version: 365 and 2016
Post by John Hammond »
The assumption seems to be when you run a process ( in Perspectives or Performance Modeller) then you need to refresh the entire client cache as the client does n't know what the process has changed on the server.
This takes ages in Perf Modeller and non citrix Perspectives. Mostly the cached info is unchanged, and if it is you can always use F5 to refresh.
Would a setting in the client "Refresh Client Interface on Running Process" Y/N be possible? It would very cheaply make stuff that's unusable, usable.
Re: Choose to "Refresh Client Interface on Running Process"
You may want to have a look here and post if not already covered. This seems to be the new area for ideas and possibly replaces the old RFE site (which looks still to be active)
BR, George.
