I am seeing some WARN messages in the message log, the message reads:
TM1.Dimension Object Name is Blank
It appears this error is against a process which ODBC's to a sql database
Does anyone have any ideas what could trigger this error?
Maren
Message Log WARN
Re: Message Log WARN
Yes. Trying to insert an element into a dimension where the element is blank.
MarenC
- Excel Version: Excel 2016
Hi Wim,
Does this only appear when the source is ODBC?
I tried testing with a csv data source, had 3 rows in the source, made the middle row blank and did dimensionelementinsert and when I ran the process it just inserted the 2 populated rows and ignored the blank one?
Maren
Maren
I encountered this with ODBC data sources only, so that seems to be the case.
This can happen in regular dimension updates as well. I see it in the Prolog tab where the function "DimensionElementComponentAddDirect" is used.
If the parent for instance is empty, you get this one.
