has anyone managed to run/schedule a TI process from the Cognos 8 Portal?..
We need to integrate Planning jobs with TM1 jobs.. and run it all from the C8 portal.
Run TI process from the C8 portal
Herman Moller
Re: Run TI process from the C8 portal
I am not sure you can run a TI process via a C8 portal, but what you could do is put your processes in a TM1websheet and run the process through TM1web portal of C8.
