Could not log on to any of the available servers with available credentials over internet
tiagoblauth
OLAP Product: TM1, Cognos BI
Version: 10.2.1
Post by tiagoblauth »
Hi friends, :)
I have problems accessing pmpsvc over the internet.
Within the local network, everything works: tm1web, pmpsvc, architect, modeler, perspectives.
http://{ip_address}:9510/tm1web -> works, I can access views, cubes
http://{ip_address}:9510/pmpsvc -> Could not log on to any of the available servers with available credentials :o
tm1s.cfg parameters
IntegratedSecurityMode=1
I did open the following ports:
9500 - main port
5495 - TM1 Admin Host
5498 - TM1 SSL server​
93000 Dispatcher
Am I missing ports? Any tips?
Thanks in advance.
Version: PA 2.0.7
Re: Could not log on to any of the available servers with available credentials over internet
Post by jim wood »
You need to check with your IT department. The security credentials (hand shakes etc) tend to be more aggressive for outside access. Is the server even available to the web? Most servers I work with have no net access,
Jim.
tiagoblauth
Version: 10.2.1
Hi Jim, many thanks for your answer.
I can access http://{ip_address}:9510/tm1web from external access.
Is it just pmpsvc that is not working from external access.
Version: PA 2.0.7
Post by jim wood »
tiagoblauth wrote: Tue Oct 15, 2019 11:51 am Hi Jim, many thanks for your answer.
It may be a script that's being blocked? This may be one for IBM. Support will have a better idea of how to log such things.
