TM1 Data Movement From Source To Target (Use Ti instead of DBS)
jboulay
Version: unknown
Post by jboulay »
Please help if you can.
I have data in a source data in operating unit#555 and team #12222 that I would like to transfer to a target data in operating unit#802 and team #14444 in attached sample. I been doing this by first zeroing out source data then using DBSend to load to target ( a pain to do) . Is there a way to instead build a Ti process to do this?
TM1 for Ti test.xlsx
(12.01 KiB) Downloaded 313 times
Re: TM1 Data Movement From Source To Target (Use Ti instead of DBS)
jboulay wrote: Mon Oct 07, 2019 6:53 pmI been doing this by first zeroing out source data then using DBSend to load to target ( a pain to do)
Of course it’s a pain to do so, if you first zero out the source. I hope that’s a typo.
Sure you can use TI. Use Bedrock or have a look at those typical TI scripts to move data intra cube.
