Configuring Postman to test MDX requests
Posted: Tue Oct 01, 2019 3:28 pm
by djuste
I would like some help on Postman configuring. I aim testing MDX requests through Postman as I prefer avoiding PAWS.
The TM1 server works fine. Its version is IBM Cognos TM1 Server Application 11.0.6.71-0. Integrity mode is set to 5. My account is correctly set as I permanently use it with Architect.
I receive correct answer when using this URL : http://isd-tm1:12355/api/v1/$metadata
I would like to configure Postman to send MDX to TM1 server (isd-tm1). But I'm facing some trouble. I don't know why the server is always answering an http 401 error (unauthorized). Here are the header settings :
Authorization : CAMNamespace ("account":"password":"namespace")
Accept : application/json
Content-type : application/x-www-form-urlencoded
In body, I put the MDX request.
I'm sure account & password are correct.
I call this URL : http://isd-tm1:12355/api/v1/ExecuteMDX?$expand=Axes($expand=Hierarchies($select=Name),Tuples($expand=Members($select=Attributes))),Cells($select=Ordinal,Value,FormattedValue,Consolidated)
So, any idea what's wrong ? Did I forget a parameter in header ?
Thanks in advance.
I will give any additionnal piece of information if needed.
Re: Configuring Postman to test MDX requests
Posted: Tue Oct 01, 2019 3:44 pm
by ascheevel
The link below might be a good resource
https://code.cubewise.com/blog/masterin ... th-postman
EDIT:
Sorry, was re-reading your post and the link I provided and I'm not sure now how much help that'd be for you. Have you tried setting the content type to application/json and passing the mdx as json payload via POST method?
Posted: Wed Oct 02, 2019 6:57 am
by djuste
Hello, thanks for your help.
I think I should use POST method instead of GET. I'm testing it. I will be back soon to tell you.
