Continuous time link to discrete time dimension
WayneBo
OLAP Product: TM1 Planning Analytics
Version: 2.0
Excel Version: 2019
Post by WayneBo »
Hi All:
I have a question regarding to the 2 different types of time dimension (continuous vs discrete)
I have an occupancy cube using continuous time dimension on daily level to record the daily occupancy number.
Continuous time dimension has 4 levels, Year-Month-Week-Day.
Then, I have budget cube using the discrete time dimension ( have year dimension, month dimension ).
In this budget cube, I have budgeted occupancy on monthly level.
Now, I want to compare the actual vs budget occupancy on a daily level.
I am able to do a rule in budget cube to calculate the daily budget number by divide the monthly budget number by the month days (Dim Month attributes).
But I don't know how do I transfer the calculated daily budget number ( which on month level in a discrete time in budget cube) to the daily occupancy cube ( which is using the continuous time on daily level) in the relevant (correct) month and year.
Could and TM1 expert kindly provide help.
Thank you
W
orlando
Version: PAL 2.0.8
Re: Continuous time link to discrete time dimension
Post by orlando »
WayneBo wrote: Fri Sep 27, 2019 1:33 am Hi All:
here is my very fast idea - early in the morning ;)
You need a "Month" Attribute on the day.
You then have a rule in your actuals cube, that reads the Month Attribute from the day in a DB rule to get the figures from the budget cube.
Could be somethink like that
['budget_Element_in_actual_cube'] = N: DB('budgetCube', Dim1, Dim2, ATTRS('DimWithDay', !DimWithDay, 'Month'), 'DailyBudget');
orlando
WayneBo
Version: 2.0
Excel Version: 2019
Post by WayneBo »
Hi Orlando:
Thanks for your help.
I did small sample test, and it works.
But that bring me another question.
How do I mass edit my continuous time dimension attributes?
When I built the continuous time dimension, I didn't populate the Year and Month attributes, and this dimension been used in so many cubes already.
Is there a way that I can mass edit the attributes of a dimension after the dimension been created already?
Please kindly advise.
Thank you
W
orlando
Version: PAL 2.0.8
Post by orlando »
WayneBo wrote: Fri Sep 27, 2019 6:42 am Hi Orlando:
How does you dimension look like? Could you post a screenshot?
Use a TI process to with the a level zero subset of the dimension as a datasource and write the attribute to the dimension
or
use the DBSA formula to write the value from Excel
WayneBo
Version: 2.0
Excel Version: 2019
Post by WayneBo »
Hi Orlando:
The below is my dimension screen shot.
As you can see, I am at the moment, manually adding the year number and month number to the 2 newly add attributes of the dimension on day level.
Just wandering , if there is a fast way / automatic way to do this process, maybe by using rules or formulas?
Thanks a lot.
W
You could add an alias to your existing Month dimension to store 01, 02 etc. for Jan, Feb and so on.
On your Time dimension add a new attribute for Month and a rule to derive the Month (Jan, Feb...) by parsing the month from the element (subst first 2 characters) against your month dimension.
You may want to also create a Year element and populate it by rule using a subst on characters 7-10
You will need to consider rules for your leaf levels as well as each other level in the various hierarchies.
Hope this helps.
BR, George.
orlando
Version: PAL 2.0.8
Post by orlando »
WayneBo wrote: Fri Sep 27, 2019 12:33 pm Hi Orlando:
yep - there is.
Rule or TI.
If you're using a Rule - you don't have to worry about new elements
somethink like that should work - https://exploringtm1.com/subst-tm1-function-use-syntax/
Year = SUBST(!DimensionWithDay, 7, 4);
for the day u the same
if you don't like a rule you can use SUSBT in an TI.
best regards and have a nice weekend
orlando
WayneBo
Version: 2.0
Excel Version: 2019
Post by WayneBo »
Thanks Orlando, thats help a lot.
W
