Hello All,
I have created a new tm1 server instance through cognos configuration. Now it is created and displaying in tm1 architect. But when i am trying to access it by clicking on it, it does not respond.
Do i need to add the users at first or will it open automatically using integrated login.
Can anyone help me how to access newly created tm1 server instance, i have just created from cognos configuration by copying the config file of other instance.How to approach it.
How to access newly created tm1 server instance
- jim wood
- Version: PA 2.0.7
Re: How to access newly created tm1 server instance
How have you configured the security? Which mode 1-5? Are you using CAM? You need to give us much more details,
Jim.
Jim.
What about port numbers - are they unique ?
- gtonkin
What version? Using SSL? Certificates updated if 10.2?
Emixam
Are you able to log on ? Can you show us what you see ?
1) Here's how to add an existing TM1 Server in Cognos configuration: https://www.ibm.com/support/knowledgece ... erver.html
2) Did you use an existing data folder ? If yes, then you should use the user/password from that server.
spartan
- OLAP Product: IBM cognos
- Excel Version: 2013
Emixam wrote: ↑Tue Sep 03, 2019 6:54 pm Hi,
Step 1 is already done, and it is showing the server name under tm1 admin server in architect.
But when i double click it it is not showing anything.
I have used data folder from other server instance, hiw to use user/ password from the server.
My integratedsecuritymode is 1 .
Emixam
Did you change the PortNumber ?
A quick google search and I found this : Client shows list of TM1 Servers but cannot connect to any of them
spartan
Emixam wrote: ↑Wed Sep 04, 2019 12:18 pmDid you change the PortNumber ?
Changing the port number worked.
Thanks.
You're welcome.
