[Excel] TM1 Get Value from Cube VBA
HighKeys
OLAP Product: TM1 / TM1 Web / Perspectives
Version: Planning Analytics V2.0.9
Post by HighKeys »
how can i get a value from a cube in VBA?
I tried to send the DBR Formula via "Application.Run" but it seems not to work.
Function GetNumberFromTM1(Server As String, Cube As String, ParamArray arg() As Variant) As Long
    ReDim Z(UBound(arg()))
    For i = 0 To UBound(arg())
        Z(i) = arg(i)
    Next i
    send = "DBR(" & Chr(34) & Server & ":" & Cube & Chr(34) & ";"
    For i = 0 To UBound(Z())
        'Gerade Param elemente
       ' If i Mod 2 = 0 Then
            send = send & Chr(34) & Z(i) & Chr(34) & ";"
      '  Else
      '  End If
    Next i
    GetNumberFormTM1 = Application.Run(send)
End Function
Thanks for your help!
Re: [Excel] TM1 Get Value from Cube VBA
You don't put the arguments to DBR in brackets like that when you are using Application.Run. DBR is the first argument (in quotes), and the other arguments are separated by commas.
HighKeys
Post by HighKeys »
thanks! i was too deep in the formula when i coded this...
        Z(i) = arg(i)
    Next i
    send = Chr(34) & "DBR" & Chr(34) & "," & Chr(34) & Server & ":" & Cube & Chr(34) & ","
        If i = UBound(Z()) Then
        Else
            send = send & Chr(34) & Z(i) & Chr(34) & ","
        End If
    Next i
Now i changed the formatting from "send" to the Application.Run syntax, but still it says the macro is missing.
Any idea?
Thanks you so much!
Edit:
Here is the working Code:
        Z(i) = arg(i)
    Next i
    send = "DBR(" & Chr(34) & Server & ":" & Cube & Chr(34) & ","
            send = send & Chr(34) & Z(i) & Chr(34) & ")"
        Else
        End If
    Next i
    t = Application.Evaluate(send)
    GetNumberFromTM1 = t
End Function
Thanks for the Help!
