I hope somebody can help me with this one...
When specifying data to be imported into TM1 via the SAP connector, it is possible to set certain restrictions on which months, etc should be exported from SAP. I am now trying to specify that all leaf elements of a specific consolidator be exported by using a report that only contains the leaf elements. In SAP all that would be required is to select the specific consolidator and only the relevant leaf elements would be exported.
I've thought of limiting the export by range, but unfortunately that is not an option since the elements are all over the place. I also can't export everything and then only use what I need, so I really need to get this working. Does anybody have any experience to share on this issue?
Tx in advance
G
