Rule or Process?
Posted: Fri Aug 16, 2019 10:41 am
I have a cube with four dimensions,
lets call them
Dim1
Dim2
Dim3
Dim4 - Measure dimension
In dim 4 there is a measure called DaysTaken
I want to be able to create bandings for DaysTaken, so the following bandings:
Band1 = DaysTaken between 1 and 4
Band2 = DaysTaken between 5 and 15
Band3 = DaysTaken between 15 and 30
Band4 = DaysTaken greater or equal to 30
My thought was to create these bandings as a flag measure in Dim4, the measures dimension and
then have a rule for each band, so for example
[Band1] =N: If( [daystaken] >=1 & [daystaken] <=4, 1,0);
[Band2] =N: If( [daystaken] >=5 & [daystaken] <=15, 1,0);
etc
The problem comes when trying to report off this, so say I have another measure in Dim4 called sales, how do I report the total value for sales where Band1 =1 etc?
update: I do have something that kind of works, so instead of separate measures for Band1, Band2 etc, I created a single measure called Bandings which returns either Band1, or Band2 depending on daystaken. I then created 4 measures which capture sales by banding, so for example:
[SalesByBand1] = N: If(['Banding'] @= 'Band1', ['Sales'],0);
[SalesByBand2] = N: If(['Banding'] @= 'band2', ['Sales'],0);
etc
Maren
lets call them
Dim1
Dim2
Dim3
etc
etc
Maren
