TM1 Workflow on the Web
appleglaze28
Post by appleglaze28 »
I'd like to ask how c'mon I added all the files for TM1 Workflow in my data directory. It works on Excel, however in TM1 I can't see the TM1 Workflow appear above. I'm not sure how to troubleshoot this problem. I've already tried it before on a VMWare and it is working perectly.
Re: TM1 Workflow on the Web
In web.config do you have DisplayCustomToolbar=Y
appleglaze28
how do i check that?
appleglaze28 wrote:how do i check that?
Look on your server; the file will probably be found in C:\Inetpub\wwwroot\TM1Web. Open it in Notepad and do a search for the key that LotsaRam mentioned.
You'll find the relevant information on page 6-50 of the 9.4 Operations Guide.
