I'm using PAX 2.0.8
We have a new process that connect through ODBC to a view in Oracle 11g.
While i'm getting results in PL-SQL, tm1 showing me only the view headers (wo data).
Based on posts in this forum, I already done the follows without any success.
1. Checked that cfg file contains:
SQLFetchScroll=T
UseSQLExtendedFetch=T
2. I checked only one column to make sure there is no problem with one of the column and it still shows nothing
Thanks for helping
Roei
No ODBC preview
- jim wood
- Version: PA 2.0.7
Re: No ODBC preview
Are you using the same user in the ODBC as you are when running the query yourself? Sounds like security rights for the ODBC user to me.
- roei61
- OLAP Product: PAX
- Version: 2.0.7
Re: No ODBC preview
Thanks for your answer.
Yes, it's the same user and still don't work
Roei
Roei
Paul-TM1
Re: No ODBC preview
Do you still have the issue? I think only one of the parameters cab be used in one setting. I am not sure.
Paul.
Paul.
