DBRW formula works for development server but not for production server
BilalSuleman2019
Post by BilalSuleman2019 »
DBRW formula is not working for production server but is working for development server. Production server is replica of development server.
Can any one help?
Bilal
Re: DBRW formula works for development server but not for production server
Probably because the formula is still pointing to the development server. If this is not the case then post a screen shot of the formula and all the cells it is pointing to.
BilalSuleman2019
Thanks you tomok for your reply. I have check by signing out of development server and signing in to production server. The problem is still there. Please see the screenshot of the formula and all the cell it is pointing to.
Bilal
Are your development TM1 database and your production database called the same thing?
BilalSuleman2019
Yes, both development and production server TM1 database has same name.
This should be a simple issue.
I'd try the DBRW in totally fresh session versus the live server, rather than switching admin servers and relogging.
My best guess from your screen shot is that one of the cell references is not evaluating properly when the DBRW calcs since the DBRW is returning #Value.
You just need to step through the references and check them all for issues. Maybe range value them all.
BilalSuleman2019
Sorry for late reply but the issue was resolved by external consultant. Access rights was not defined for all elements in one dimension in production server due to which DBRW formula was not working.
Thanks to all for help
Best Regard
Bilal
