PAW Button does not give RUN Process option
Posted: Mon Jul 15, 2019 10:43 pm
by mnasra
Hi Experts,
I need to add a button in PAW to give the user the ability to run a process.
I saw it on IBM Cloud.
But I cannot see it in my environment and I am a Workspace and Tm1 administrator.
thanks
Re: PAW Button does not give RUN Process option
Posted: Mon Jul 15, 2019 10:50 pm
by Wim Gielis
What version do you use ?
Posted: Tue Jul 16, 2019 9:54 am
by declanr
To add to Wim's point - the ability to run processes from buttons in Workspace only got added in PAW 39 which was released in March.
In earlier versions you will still need to add an action button to a websheet via PAX and then load that into your PAW book.
https://www.ibm.com/support/knowledgece ... s_paw.html
Posted: Tue Jul 16, 2019 11:10 am
declanr wrote: ↑Tue Jul 16, 2019 9:54 am To add to Wim's point - the ability to run processes from buttons in Workspace only got added in PAW 39 which was released in March.
The ability to automatically refresh a book after completion of a process, rumored to be coming in PAW 44.
The ability to pass context of SUBNM selections to process parameters sometime beyond PAW 44.
In the meantime there's always TM1Web (or embedding TM1Web within PAW).
Posted: Tue Jul 16, 2019 1:48 pm
by mnasra
THANK You all. YES, you are right. I am at version 36. Did not even occur to me to compare versions.
Thank you again.
Posted: Tue Jul 16, 2019 1:51 pm
by Wim Gielis
mnasra wrote: ↑Tue Jul 16, 2019 1:48 pmTHANK You all. YES, you are right. I am at version 36
Certainly with PAW where versions change every couple of weeks.
