TM1WEB page not responding
vino1493
OLAP Product: cognos tm1
Excel Version: excel 2013
Post by vino1493 »
I installed PA 2.0.6, saved default configuration setting post installation and started TM1 application server and Admin server.
TM1web was accessible at: HTTP://localhost:9510/tm1web/
But suddenly TM1WEB stopped working few days back. I reinstalled PA 2.0.6, but again TM1WEB page is not responding.
Getting "This site can't be reached. Local host not responding".
I also tried using netstat -naob, but no other service uses 9510.
How to tackle this situation?
macsir
Version: PAL 2.0.9
Re: TM1WEB page not responding
Post by macsir »
enable tm1web log and you can see the details.
vino1493
Post by vino1493 »
Thanks for the comment..
Could you please tell me how to enable that and where I check the error log?
macsir
Version: PAL 2.0.9
Post by macsir »
vino1493
Post by vino1493 »
I enabled tm1web logging, saved and closed the file. Then restarted both admin and applications servers using cognos configuration.
Tried logging into tm1web url. But I don't see the logs folder or log file.
macsir
Version: PAL 2.0.9
Post by macsir »
Can you find this folder or not "TM1_INSTALLATION_PATH\webapps\tm1web\WEB-INF\logs"? Please put some snapshots here.
vino1493
Post by vino1493 »
That folder is missing. I will share a screenshot once I login.
WEB-INF directory
WEB-INF directory
macsir
Version: PAL 2.0.9
Post by macsir »
Can you check log4j.properties file is there? And the content of it is correct? Or even you are checking the wrong server?
You can change the logging message level for IBM® Cognos® TM1® Web logging.
Logging properties are stored in the log4j.properties file in the following location:
<TM1 install location>\webapps\tm1web\WEB-INF\configuration
Logging for Cognos TM1 Web is configured and enabled by default when the program is installed.
https://www.ibm.com/support/knowledgece ... 51964.html
vino1493
Post by vino1493 »
log4j.properties this file does exist, but nothing happens.
I tried changing the configuration levels from DEBUG to ERROR (tried various combinations using the link you provided last week itself).
Again, no change. That "logs" folder does not appear.
vino1493
Post by vino1493 »
Does PA need IIS? should I enable it?
macsir
Version: PAL 2.0.9
Post by macsir »
Yes
vino1493
Post by vino1493 »
Then what is the use of tomcat? Do we really need IIS, as tomcat is inbuilt?
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
On PA 2.0.6, you do not need IIS or Tomcat (if you have a default installation). Everything is built on Websphere Liberty
