Hi Expert,
I have a problem with the installation (or parameters) of the Planning Analytics Workspace. Under the database menu , I only can see the applications and cubes. I cannot see the dimensions nor the processes. I am definitely connected as an Admin.
I can go down to the dimension of a cube and do everything I need with dimensions. (the long way).
But not processes.
thanks
PAW Cannot see the dimension or processes
mnasra
- Version: 2.0
- Excel Version: EXCEL 2013
Micheline
Micheline
Re: PAW Cannot see the dimension or processes
You need to be defined as a modeler or administrator in Workspace. This is above and beyond and security set in tm1 for the model. The workspace administrator who set you up can do this.
mnasra
- Version: 2.0
Thank you very much Declanr.
yes you are right, I dont seem to be the administrator of Workspace.
Micheline
Micheline
Emixam
You should take a look at this one:
https://www.ibm.com/support/knowledgece ... users.html
Cheers !
Cheers !
