Connect to TM1 server using VBA
Posted: Mon Jul 01, 2019 2:36 pm
Hi guys,
I need to connect to TM1 server using VBA. I tried using "N_Connect" and it is failed with the error "Login Failed: SystemServerCAMSecurityRequired"
I have some TM1 functions and expressions in the worksheet which will get executed and populate the data once connected. I need to achieve this by making a connection to TM1 server using VBA. Once the data is populated, need to disconnect as well.
I am very new to this and any help is appreciated
Thank you !!
Thanks & Regards,
Manoj
Thank you !!
Thanks & Regards,
Manoj
