TM1 service holding open ODBC?
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Post by Mark RMBC »
does anyone know if the TM1 service can hold open an ODBC connection permanently for a TI execution?
We have some issues and IT have said TM1 is holding open an odbc connection and preventing some backups
cheers, Mark
Version: PA 2.0.7
Re: TM1 service holding open ODBC?
Post by jim wood »
In the same process do you have ODBCClose in the prologue?
Jim.
Mark RMBC
Version: 10.1.1
Post by Mark RMBC »
Hi Jim, thanks for the reply.
No there is no ODBCClose in the prologue or anywhere in the process for that matter
cheers, Mark
Bakkone
Post by Bakkone »
Then you have to add one.
Mark RMBC
Version: 10.1.1
Post by Mark RMBC »
Hi Bakkone,
On the prologue? Won't that affect the meta and data tabs?
I presume JIm had something else in mind?
cheers, Mark
Version: PA 2.0.7
Post by jim wood »
Sorry I meant the epilogue. In my defense it was first thing in the morning and there wasn't even a sniff of caffeine yet!! So yes close the ODBC in the epilogue. :oops:
Mark RMBC
Version: 10.1.1
Post by Mark RMBC »
No problem and thanks for the advice!
Bakkone
Post by Bakkone »
Try to add some validations and other checks that also triggers a close. Otherwise you risk having the connection stay open because of an error.
Or if you know that the DBAs are running backups at night. Add a process with ODBC close in your own nightly backup routine.
