Hi, I am writing a TI to update data in a cubes in one application. This needs to be followed by change data in a cube in another application also.
So is it possible to write a TI process to update values in a cube in a different application ?
or
How can I have a TI process from one application call another TI process from another application and pass a string parameter. ?
Rtel
Updating cubes across different applications with TI
ascheevel
- Version: PA 2.0.9.1
- Excel Version: 365
Re: Updating cubes across different applications with TI
You can use RunTI to call a TI process on another TM1 server. You can pass parameters to the called process when using RunTI.
https://www-01.ibm.com/support/docview. ... 6543&aid=1
What do you mean with Application ? A websheet / view / ... or is a TM1 server (model) ?
It it's a different model you could look at TM1RunTI.exe (or similar solutions but TM1RunTI.exe is the basis).
Rtel
- Version: 10.2
- Excel Version: 2013
Hello All, Thanks for your responses. I will explore the direction provided.
Hi Wim, by 'Application' I meant a TM1 server modal.
Rtel
Rtel
