HELP needed: XML error in TM1 Web
harrytm1
Version: Latest version
Excel Version: 2003 to 2019
Post by harrytm1 »
Hi fellas,
I need help on this error that I encounterd in TM1 Web.
"Error occured while converting the MS Excel workbook into XML format : Unable to get the HorizontalAlignment property of the Textbox class."
Here's the set-up:
PC A which is used to create the Excel report
TM1 Web XML Error message.jpg (16.31 KiB) Viewed 2840 times
- Excel 2003
- TM1 9.4.1 FP002
- Win Vista Home Premium
PC B which takes the Excel report created by PC A and loads it as Application. It then runs a localhost TM1 Web.
- Excel 2007
- TM1 9.4.1 FP0002
- Win XP Pro
PC A is able to convert the Excel file into Websheet in localhost TM1 Web, but PC B encounters the mentioned error. Seems like this is due to different version of Excel used by the TM1 Excel Service during conversion.
Funny thing is, the file was workingg fine previously. So I thought of the changes that were made on this version. On PC A, I change the property of a group of objects (inlcuding images and text boxes) under "Object Positioning" in Excel to from "Move and size with cells" to "Move but don't size with cell". Could this be the issue? Sadly, I do not have PC B right now, so I'm unable to confirm this immediately.
Anyone encountered this before?
pradeep.k.jagadeesan
OLAP Product: IBM Cognos TM1
Version: 9.5.1
Re: HELP needed: XML error in TM1 Web
Post by pradeep.k.jagadeesan »
Hi harry,
i have also encountered the same error. If you have included any text boxes that is belongs to MS Excel, you will get this error. Remove all MS Excel related objects from the template, it will work fine.
