File is open in IBM Cognos TM1 Server
Posted: Fri May 24, 2019 8:14 am
Hi everyone,
I am using Planning Analyrics 2.0.6. I have run a process which uses a text file as a data source. After running the process successfully, when i rename or delete the text file, it said "The action can't be completed because the file is open in IBM Cognos TM1 Server". The situation happens occasionally. When i copy the same file to UAT environment and run the same process (same code), there is no problem.
Anyone encountered the same problem before? Please help.
Besides, i would like to ask how to check whether the TM1 server is using the file and stop TM1 server to open it.
I opened tm1top but there is no any process running. Currently, my fixing method is to restart the tm1 server. But it spends too much time, hope there is any alternative way to end tm1 using the text file.
Thank you,
Alex
Thank you,
Alex
