HI Team,
We are on 10.2.2. Fix pack 7, recently updated from fix pack 3 to 7
We have a tm1 application form which allows user to write back to the cube, there is data validation set on the form to select the values.
When ever vlaues are updated on the web version the new values used to write back to the cube immediately.
Recently I noticed , users need to refresh the page by clicking on F9 to update the values on the page and also to write back to the cube.
Is it something related to Web config?
Thanks In advance.
Neelima
Tm1 Application - update
- gtonkin
Re: Tm1 Application - update
But based on your note about data validations, look at TM1 Web Configuration Parameters, specifically the RecalcOnDataValidationChange parameter - may have been updated/lost when upgrading TM1 web
Could also be that Sandboxing was previously disabled in your TM1S.CFG
Have a look at Disable Sandboxing
